need wiring diagram on delco radio 1991
gerv28
Posted: January 09, 2005 at 6:02 PM / IP Logged
hello!  I need the wiring diagram on a delco radio 1991 part no. 30004038 (16139841).  Thanks you.
geepherder
Platinum - Posts: 3,668
Posted: January 11, 2005 at 9:46 PM / IP Logged
What are you trying to do?  There are many people here who can offer useful help if you give us more information.  Do you just need the pinout of the harness?  Does the unit no longer work, what?
Charlot888
Member - Posts: 7
Posted: January 16, 2005 at 10:22 AM / IP Logged
yes i need diagram and pinout (colors). thanks
geepherder
Posted: January 16, 2005 at 11:48 PM / IP Logged
If you're just installing a new radio, use a harness adapter from your local sound shop (even WalMart).  If your plug has been cut off, check here:
https://www.the12volt.com/installbay/vehicles.asp
also www.installdr.com
If you're trying to repair the old unit, a common problem is the power button.  Take the unit apart from the bottom, remove the cassette portion, and bypass the switch.  See if the unit now comes on.
gerv28
Posted: January 17, 2005 at 5:49 PM / IP Logged
Thanks you very much!!!!
steeve
