would this sub and amp work out ?
mandawanda
Member - Posts: 8
Posted: January 09, 2005 at 9:16 PM / IP Logged
kicker solo baric L5 dual 2 ohm voice coil sub running bridged on a soundstream xta600.2 amp
the specs for the amp are
  • Soundstream Xstream Competition 600 Watt Bridgeable 2 Channel Amplifier
  • Continuous Power Output @ 4 Ohms Stereo: 150 Watts (rms) x 2
  • Continuous Power Output @ 2 Ohms Stereo: 300 Watts (rms) x 2
  • Continuous Power Output @ 4 Ohms Bridged: 600 Watts (rms) x 1
  • Low Total Harmonic Distortion Level Of 0.05%
  • Integrated Electronic Crossover Network
  • User Selectable High/Low Pass Crossover
  • High Pass Crossover Continuously Variable From 30 Hz To 500 Hz
  • Low Pass Crossover Continuously Variable From 30 Hz To 150 Hz
  • Crossover Slope Of 12 dB/Octave
  • Built In Bass Enhancement Circuitry
  • Bass EQ Variable From 0 To + 18 dB
  • Phase Inversion Switch
  • Thermal Protection Circuitry
  • Overload/Short Circuit Protection Circuitry
  • Small And Compact Design: 12.4" x 24.9" x 3"
  • 4 Gauge Power Platinum Connectors
  • Tri-Mode Operation
  • twofootthumpin
    Member - Posts: 39
    Posted: January 09, 2005 at 9:32 PM / IP Logged
    Depending on the way that you have the subwoofer set up in line with the voice coils it would and would not work. If you set the voils coils in series it would work with that style amp, even though the sub would be under-powered it would still thump hard enough at 600 rms, but if you set the voice coils in parallel it would not work the way you would want it too, let alone the amp is not rated for less than 4 ohms bridged which would run the amp at an extermely hot temperature and would draw a lot of extra amperage from your system and would also hurt the clarity of the sound that gets produced.
    wheelerdr
    Copper - Posts: 337
    Posted: January 09, 2005 at 9:36 PM / IP Logged
    twof is right you do not want to hurt your amp is you want to keep it very long, the only way i see it is run series to bridge it or run one ch to one coil and the other ch to the other coil, this would be 2 ohm stero eith way you get 600 rms 300 per coil
    kfr01
    Gold - Posts: 2,121
    Posted: January 09, 2005 at 9:38 PM / IP Logged
    Bridge it to 4ohms. 600w is fine for that subwoofer, FAR Far far from underpowering it.
    New Project: 2003 Pathfinder
    mandawanda
    Member - Posts: 8
    Posted: January 10, 2005 at 2:28 AM / IP Logged
    so would it be better if i buy the 4ohn version of this sub? what amp would you recoment
    wheelerdr
    Copper - Posts: 337
    Posted: January 10, 2005 at 6:37 AM / IP Logged
    stay with what you have for now
    twofootthumpin
    Member - Posts: 39
    Posted: January 10, 2005 at 7:39 AM / IP Logged
    Stay with the amp until you upgrade, it will do just fine as long as you stick with series style wireing, the sub is rated at 600 watts rms per voice coil which means that you wont have to worry about blowing the sub when you start beating on it, but yet it will still beat the piss out of your trunk. The set up sounds like it would make a very nice starter system with alot of upgradablity.
    kfr01
    Gold - Posts: 2,121
    Posted: January 10, 2005 at 8:29 AM / IP Logged
    You're totally fine with what you have now.  Unless you plan to compete in SPL competitions you'll probably never hear the difference between 600w and 1200w for daily driving.
    mandawanda
    Member - Posts: 8
    Posted: January 10, 2005 at 8:59 AM / IP Logged
    ok thanks you guys helpd alot
    audiobass10
    Silver - Posts: 328
    Posted: January 10, 2005 at 9:36 AM / IP Logged
    Took the words right out of my mouth..
    Dave
    Pioneer Premier DEH-P660
    15" Kicker CVR
    Profile AP1000M
    It's Loud
