Need pin outs for Explorer subwoofer out
Victorbmw
Member - Posts: 15
Posted: January 14, 2005 at 7:50 PM / IP Logged
I need to know pin outs for out put on the 2002 explorer radio and for navigator 20043 radio
  Any help will be appreciated.
Need pin outs for Explorer subwoofer out -- posted image. victorbmw
rolln_on_em
Member - Posts: 21
Posted: January 15, 2005 at 12:41 PM / IP Logged
if the rear of the radio has a small 8 or 8 pin plug then I remember RED / black being turn on, and the other two signal wires, you do not need to hookup the uninsulated wire.
If all else fails just remove rear quarter panel to check for wirecolors to factory amp.
Also remembver to use atleast a 570ohm resistor on your turn on lead, to avoid turn on pop.
Hope this helps
Bryan
Yeah I drive a slow car; but damn it looks good
Victorbmw
Member - Posts: 15
Posted: January 31, 2005 at 8:40 PM / IP Logged
Thanks Bryan for your help  It sounds real good !
Monday, December 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
