grounding?
01redgsr
Posted: November 03, 2002 at 8:43 PM / IP Logged
anyone ever hear of a grounding post??  If so should i use one to ground my amp and cap or just ground it to the body somewhere?  What does everyone else use to ground to?
2001 Milano Red Acura Integra GS-R
1 12" JL Audio 12w6v2
1 JL Audio 500/1 Amp
1 Farad Cap by Lightning Audio
abright52
Copper - Posts: 137
Posted: November 03, 2002 at 10:27 PM / IP Logged
I usually ground to my body. Take some sandpaper and get the paint off of the place you are mounting to and then drive a screw into that spot (Be sure that you are not going to hit anything on the other side). I usually attach the ground wire with a ring terminal and drive the screw through the ring with a washer, so that everything is tight and has a solid connection.
91blaze
Member - Posts: 27
Posted: November 04, 2002 at 11:44 PM / IP Logged
i take my ground straight to the frame. i grind down to bare metal, bolt a ring terminal on, silicone around it and coat it.
Thursday, January 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
