problem with AM reception
mrnix
Member - Posts: 19
Posted: November 04, 2002 at 8:23 AM / IP Logged
I installed a Kenwood CD Player in a 2002 Honda Civic, and FM comes in fine, but I cannot get any AM reception.  Could this have something to do with the radio grounding out to metal?  What else could I check?  All I hear is a fairly loud buzz on the AM band, at every station.  Any help is appreciated.
Will
mrnix@hotmail.com
91blaze
Member - Posts: 27
Posted: November 04, 2002 at 11:45 PM / IP Logged
make sure your antenna connections are clean and solid.
mrnix
Member - Posts: 19
Posted: November 05, 2002 at 6:42 AM / IP Logged
I can double check them, but everything looked to be in order.  Is there anything else that could cause this problem?
Will
mrnix@hotmail.com
Maxima10to1
Member - Posts: 11
Posted: November 05, 2002 at 6:51 PM / IP Logged
In my experience with Kenwood, they have very poor AM/FM reception. Maybe you all need is some type of an AM booster.
mrnix
Member - Posts: 19
Posted: November 06, 2002 at 6:45 AM / IP Logged
Thanks for the help, I guess I will give that a shot.
Will
mrnix@hotmail.com
the12volt
Administrator - Posts: 3,959
Posted: November 06, 2002 at 9:07 AM / IP Logged
Rule of thumb regarding AM/FM reception...if you get FM and no AM, typically it's an antenna problem. If you get AM and no FM, typically it's a radio problem.
Before you add any type of signal booster, remove the existing antenna and check for chafing along the cable and for rust and corrosion at the mount and cable connections. Also, plug in a known good antenna and replace yours if necessary.
bberman1
Gold - Posts: 2,314
Posted: November 06, 2002 at 11:50 AM / IP Logged
Is your antenna mounted inside the glass on your rear window? Are your windows tinted?
mrnix
Member - Posts: 19
Posted: November 06, 2002 at 11:59 AM / IP Logged
The car is a new Honda Civic, and I think it has the window antenna.  Are there problems with these?
Will
mrnix@hotmail.com
