box ? with separate amps
bigwise1
Member - Posts: 39
Posted: March 07, 2005 at 11:46 PM / IP Logged
Equipment used will be 2 JL10w6v2 and 2 Zapco 500/1.
A shop recommended going with a ported common chamber box. Is it advisable to do this with separate amps? They said that they could use rta to match amps.
Ravendarat
Platinum - Posts: 2,806
Posted: March 08, 2005 at 1:28 AM / IP Logged
I am sure that you could do it using the proper equipment but why bother? Just use one more piece of wood and chamber the box and you are far better off.
bigwise1
Member - Posts: 39
Posted: March 08, 2005 at 2:06 AM / IP Logged
for that chance of extra db i guess
oonikfraleyoo
Gold - Posts: 1,069
Posted: March 08, 2005 at 11:05 AM / IP Logged
What chance of extra db? If your subs are canceling each other out in the common chamber then you will lose db.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
bigwise1
Member - Posts: 39
Posted: March 08, 2005 at 6:36 PM / IP Logged
i guess to do it the hard way. the one port will keep the box from being deeper so i at least i'll have more trunk space
bigwise1
Member - Posts: 39
Posted: March 08, 2005 at 6:37 PM / IP Logged
