Sealed Back Line Array Drivers
Wiseguy
Copper - Posts: 159
Posted: March 19, 2005 at 11:44 AM / IP Logged
any body have an  opinion on these drivers: http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Product_ID=167945&gemail=1
these really appealed to me because they were sealed, and an 150rms power handling at 8 ohms
how would these sound inside a car, along the back shelf? practical?
Clarion DXZ745MP
Kove ZX504
Kove AG1400
Kove 12" T3 Armageddon
Kove 6.5" Compaxials
WILDER 6.5" Pro-Audio Drivers
Custom Pre-amp
KarTuneMan
Platinum - Posts: 7,056
Posted: March 19, 2005 at 12:09 PM / IP Logged
Eminance has been around FOREVER, building hardcore stuff.......these look cool, one hell of a 6.5.
Good for some "rear fill"
kfr01
Gold - Posts: 2,121
Posted: March 19, 2005 at 12:37 PM / IP Logged
Back up here. Why would you need or want speakers designed for 500-3khz along the back shelf?
This just sounds like one of those ideas that will just add complexity and unevenness to your system.
I think it is a bad idea.
New Project: 2003 Pathfinder
DYohn
Moderator - Posts: 10,741
Posted: March 19, 2005 at 12:40 PM / IP Logged
I agree.  The speaker you link to is a decent mid-range driver when used as intended: in a line-array.  Not something I'd recomend putting into a car, and especially not "along the back shelf."
What is your intention and maybe we can recomend something.
Wiseguy
Copper - Posts: 159
Posted: March 19, 2005 at 2:22 PM / IP Logged
well my ultimate intension is to find a close to full range driver that i can use in the car, not components, not a coaxial, that can take alot of punishment
i want to replace my kove coaxials essentially
imaging is not a main concern for me, i want something that is efficient at  8 ohms
what do u have in mind?
Clarion DXZ745MP
Kove ZX504
Kove AG1400
Custom Pre-amp
Wiseguy
Copper - Posts: 159
Posted: March 19, 2005 at 2:27 PM / IP Logged
what is a line array?
Clarion DXZ745MP
Kove ZX504
Kove AG1400
Custom Pre-amp
ophidia31
Copper - Posts: 78
Posted: March 19, 2005 at 3:00 PM / IP Logged
"paper cone with cloth cone edge" Sealed Back Line Array Drivers -- posted image.
Wiseguy
Copper - Posts: 159
Posted: March 19, 2005 at 3:05 PM / IP Logged
materials mean nothing to me. some of the most efficient drivers use paper cones and cloth surrounds,  i have a few paper cone drivers older than me that'll rip the skin off your faceSealed Back Line Array Drivers -- posted image.
Clarion DXZ745MP
Kove ZX504
Kove AG1400
Custom Pre-amp
stevdart
Platinum - Posts: 5,816
Posted: March 19, 2005 at 3:57 PM / IP Logged
I know you're familiar with all I'm about to say but I'll put it out here just to make a clear point.   A speaker is rated at a certain impedance for specific applications, such as at 4 ohm for car audio and 8 ohm home audio, typical.  You of course can use 8 ohm drivers in the car and doing so will allow the amplifier to produce power at (normally) better specs.  The downside is that you are using only a portion of the available power, so a car amp that is rated 2 X 60 watts into 4 ohms will produce 2 X 30 watts into 8 ohms.  Efficiency doesn't factor in.  In order to use the car's power resources smarter, especially for back shelf speakers, using drivers rated at 4 ohms will allow your amp to produce power at its rated specs.  I think you would have to have very specific SQ intentions with certain up-front drivers to want to use the amp at an 8 ohm load.
The sound that comes from the rear should be very close to the same sound that comes from the front speakers so that the combination will blend in the car and create a "spot" of focus somewhere around the front seat occupants' heads.  A full-range driver, in order to produce something close to full range music, has to have some sort of way to produce both midbass and high freqs.  They usually have a whizzer cone in the center that will successfully reproduce the high freqs that the main cone will not.  There is no crossover involved with that concept, it's just because of the limitations inherent in cone sizes.  OEM speakers in cars, and tabletop radios, have used these whizzer cone full-range speakers since before I was born.
I don't think that's what you really want.  The sound will differ from the sound from your fronts.  What do you have in the front, anyway?
BTW, I was searching for a pic of a line-array and couldn't find a good example yet.  But picture a tall, narrow floor-standing speaker system sitting beside a big screen TV with about 10 or more speakers all the same size lined up and down it, packed real close together.
Wiseguy
Copper - Posts: 159
Posted: March 19, 2005 at 4:04 PM / IP Logged
i have 8 ohm drivers up front
btw i know 8 ohm speakers on an amp will run at half the power, thats not really my concern
Clarion DXZ745MP
Kove ZX504
Kove AG1400
Custom Pre-amp
Page of 4
