What is going on with this system?
Lubuspl
Copper - Posts: 55
Posted: March 24, 2005 at 9:52 AM / IP Logged
I installed this system maybe 3 weeks ago. It worked fine for about a week and a half.
Then the person who I installed it for took it out and somehow when he connected the amp back the amp was not reading the ground (when you tested the ground it has a positive power give off). At this time I changed the ground to a different place and the system worked fine for about another week or so.
Now the fuse by the battery broke, and I changed it. The next day it broke again, should I get another fuse and try again or should I just send this Sony 1600 watt amp to their crappy factory.
Anyone any idea?
SoundExplosion
Copper - Posts: 48
Posted: March 24, 2005 at 10:20 AM / IP Logged
What gauge power wire are you using ? and what size fuse  do you have inline to the amp at the batt. ?
SoundExplosion
"You are only as good as your last install"
" T-taps should never be used"
Lubuspl
Copper - Posts: 55
Posted: March 24, 2005 at 10:35 AM / IP Logged
Its a 8 gauge power wire and I am not sure what size it the fuse but it came with the kit and I replaced it with the same one or even a little stronger from the store. (its one of the thick ones not the tiny one)
Francious70
Silver - Posts: 629
Posted: March 24, 2005 at 11:24 AM / IP Logged
Wasn't this the exact same question that was asked last week??
Either way, the amp is bad.
Paul
DYohn
Moderator - Posts: 10,741
Posted: March 24, 2005 at 12:09 PM / IP Logged
DON'T BE A FOOL.  NEVER simply keep replacing fuses!!  A fuse is there for a reason: to keep your car from going up in flames.  If one is blowing, find out why and FIX the problem before you simply keep replacing it.  BASIC electrical safety.
If you do not understand what is going on with the system take it to a shop and get some help.
KarTuneMan
Platinum - Posts: 7,056
Posted: March 24, 2005 at 12:56 PM / IP Logged
your  amp is toast.....too small guage power wire won't cause the amp ground to show voltage.....its an internal problm. And yes, even for that little "1600 watt" sony....8 guage is too small!
specialauto
Member - Posts: 45
Posted: April 11, 2005 at 10:04 AM / IP Logged
all i have to say... is sony is junkWhat is going on with this system? -- posted image. big shocker there
Canadian Auto Sound
Starting Installer
Saturday, November 8, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
