jbl 1200.1
evanc
Copper - Posts: 148
Posted: April 15, 2005 at 8:13 AM / IP Logged
I have owned two of these amps, in two different setups.  (The first one got stolen)  In case you do not own or are familiar with one (and in that case you may not be of much help anyways) they have a front and rear inputs which strikes me as odd for a mono sub amp. I understand they can balance out the fading, but I can't understand why you'd be running that much power without a front and rear amp as well.  I'll stop blabbering now...
I once heard from a buddy of mine that getting 2F-4M to use all the inputs would help the sound.  I went out and tried it, thinking if it did not I'd return the cables.  To my disbelief, it did work.  The bass woudl considerably louder than it was before at teh same volumes.  However, I was unable to tell if the sound quality got better or worse for I didn't have it for too much longer before it got stolen.
Has anyone else heard of doing this, and if so, are there any disadvantages to doing this (degredation of sound quality) or should this have been something I should have done from the get-go on my second chance with this amp?
Thanks guys..
Francious70
Silver - Posts: 629
Posted: April 15, 2005 at 9:40 AM / IP Logged
The 4 chanell inputs are more than likely for use for 5.1 audio. The bass that the discreet left/right front and left/right rear channels can't produce would be sent to the sub.
Paul
evanc
Copper - Posts: 148
Posted: April 15, 2005 at 11:20 AM / IP Logged
So, there is no disadvantage to usign the splitter?
mikew04
Copper - Posts: 52
Posted: April 15, 2005 at 11:54 AM / IP Logged
Did you reset the gains after you did this? You might be clipping and thats why it seems louder.
6th gen Celica | Alpine CDA-9827 | Pioneer GMX962 | CDT CL components | JBL 600.1 | Infinity Reference 12
evanc
Copper - Posts: 148
Posted: April 15, 2005 at 12:41 PM / IP Logged
Yes, I did reset the gains afterwards, but at the same gain level, the output was more, which is what confuses me.  I am just unsure if the amp performs better or worse with using both inputs opposed to using just one set.
mikew04
Copper - Posts: 52
Posted: April 15, 2005 at 3:45 PM / IP Logged
Thats interesting. Ive got the 600.1, i might just have to try that and see how it works out.
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
