2 gauge connectors
derrickg
Copper - Posts: 119
Posted: May 03, 2005 at 2:57 PM / IP Logged
i am having a big problem finding 2 gauge connectors in my area which sites can i go to to get some that can be trusted with my credit card
Francious70
Silver - Posts: 629
Posted: May 03, 2005 at 3:03 PM / IP Logged
1/0 gauge connectors will fit. If you can't find 2 gauge connectors, just use 1/0 gauge.
Paul
racer427
Silver - Posts: 381
Posted: May 03, 2005 at 4:41 PM / IP Logged
Here ya go, try these guy's.
http://www.cardomain.com/shoptype/Wire+Terminals
Chris
Alpine CDA-9833 HU
Diamond Audio M661 Components
MTX Thunder T6.6 Components:rear fill:
Cadence Q400 4 Channel Mains + rears
Thunder 801D Subs
MTX 1004 10's
Dual 4g wire to rear
4g grounds
stevdart
Platinum - Posts: 5,816
Posted: May 03, 2005 at 5:43 PM / IP Logged
https://www.the12volt.com/installbay/forum_posts.asp?tid=53988&PN=2
haemphyst
Platinum - Posts: 5,059
Posted: May 03, 2005 at 8:00 PM / IP Logged
Personally, I have had better luck using a SMALLER connector than the wire gauge. It will fit more snugly to start with, and requires less smashing of the connector, or less solder, should you decide to go that way. Most connectors are really too big for the wire they SAY they are for. Since #4 connectors are pretty easy to locate, try one before you spend all of that cash on connectors for a #2 cable... I bet you'll be plesantly surprised...
racer427
Silver - Posts: 381
Posted: May 03, 2005 at 8:51 PM / IP Logged
What type of connectors are you exactly looking for? Here are some 2g ring terminals.
http://www.cardomain.com/item/ROCCPGSRT21P
http://www.cardomain.com/item/ROCCPPSRT21P
http://www.cardomain.com/item/LITBSRT2
http://www.cardomain.com/item/LITPRT2
http://www.cardomain.com/item/LITLSRT2
In any event, I have also used 1/0 guage terminals of 2g before.
Chris
Alpine CDA-9833 HU
Thunder 801D Subs
MTX 1004 10's
4g grounds
supradude
Silver - Posts: 915
Posted: May 03, 2005 at 9:34 PM / IP Logged
I second that haemphyst. I just recently had that same problem and I used 4 gauge connectors. I just opened them up a tad with a screwdriver, put the 2 gauge wire in, and crimped them with the vise. Then I soldered them. It made a very tight connection and was neat.
'85 Toy
