WinISD Question
racer427
Silver - Posts: 381
Posted: May 15, 2005 at 2:04 PM / IP Logged
Hey guy's.
I am currently trying to model up a vented enclosure for my subs. My subs are not on the list provided by WinISD so, I am trying to manually input the parameters for the subs but, I keep getting an error no matter what I do. I read the help file and followed their entry proceedure but, I still keep getting the same error. CAn anyone Help?
Here is the error: Consistancy check on following parameter groups failed.
Qts, Qms, Qes
Chris
Alpine CDA-9833 HU
Diamond Audio M661 Components
MTX Thunder T6.6 Components:rear fill:
Cadence Q400 4 Channel Mains + rears
Thunder 801D Subs
MTX 1004 10's
Dual 4g wire to rear
4g grounds
Alpine Guy
Platinum - Posts: 2,478
Posted: May 15, 2005 at 2:21 PM / IP Logged
I find when entering new drivers you have to sometimes enter the bare minimum, there always seems to be a problem with specs that manufactures give you that winisd does not like.
racer427
Silver - Posts: 381
Posted: May 15, 2005 at 2:32 PM / IP Logged
Tryed that, Just entered the Small parameters and I keep getting the same thing no matter what I enter.
UHG
Chris
Alpine CDA-9833 HU
Thunder 801D Subs
MTX 1004 10's
4g grounds
stevdart
Platinum - Posts: 5,816
Posted: May 15, 2005 at 2:35 PM / IP Logged
Change Qts to zeros and just use Qem and Qes to figure Qts.  Make sure the 'auto calculate' box is checkeed  That should fix it.
Alpine Guy
Posted: May 15, 2005 at 2:36 PM / IP Logged
try just entering qms, qts, fs, vas, xmax, spl, re, sd
Edit: ^^^ or that, he taught me....
customsuburb
Gold - Posts: 1,813
Posted: May 15, 2005 at 3:23 PM / IP Logged
I never usually never enter the qes or the vas...I enter everything else that Alpine Guy does.
racer427
Silver - Posts: 381
Posted: May 15, 2005 at 9:21 PM / IP Logged
Thanks guy's, I think that I got that part worked out, just have to figure out the rest of it now! HA HA
Chris
Alpine CDA-9833 HU
Thunder 801D Subs
MTX 1004 10's
4g grounds
