amp question
Redstorm3
Member - Posts: 38
Posted: June 06, 2005 at 12:45 PM / IP Logged
I have a Kenwood KAC-7201 amplifier that  at 4ohms it can handle 150w x 2 OR 460w x 1 bridged.  My question is if you have 2 12" subs whether they are SVC or DVC, as long as they are wired to bring a 4ohm load, for example,
amp question -- posted image.
will the amp run at the 150x2 or @ the 460w bridged?
Francious70
Silver - Posts: 629
Posted: June 06, 2005 at 1:11 PM / IP Logged
If you use option #1 the amp will put out it's rated 450 watts bridged. If you have 2 four ohm SVC woofers, the you would not be able to have a 4 ohm total load.
Paul
Redstorm3
Member - Posts: 38
Posted: June 06, 2005 at 1:27 PM / IP Logged
thanks, all i need to find are some 12" dvc subs that can handle that, any recommendations?
Francious70
Silver - Posts: 629
Posted: June 06, 2005 at 2:57 PM / IP Logged
Check your other thread.
Paul
