2 ch amp dvc sub
shkeel
Member - Posts: 25
Posted: June 14, 2005 at 11:47 PM / IP Logged
Is it bad for the sub if u take a 2 channel amp and run one channel to one voice coil and the other channel to the other voice coil?  Do they both have to be mono?
94 Camaro Z28
Jensen 7" Indash-DVD/mp3/tv
Rockford ChromeSeries 600/2
Power Accoustic 12" Dvc700rms
Rockford Power T162C
JLaudio 6.5" 75rms
PS2 Slim hardwired
Lightning Audio 1 Farad Cap
ss-installer
Silver - Posts: 444
Posted: June 15, 2005 at 12:12 AM / IP Logged
its ok to do that but the amp will feed the sub wierd as far as running stereo to one sub. ive done it before with no problems. keep the balance centered up.
haemphyst
Platinum - Posts: 5,059
Posted: June 15, 2005 at 12:27 AM / IP Logged
Or, if you are that worried about it, wire the voice coils in series, and bridge the amp. The net impedance is the same, and you don't have to worry about it...
