Brutus 1000d mono amplifier question
dmkicker
Member - Posts: 6
Posted: June 17, 2005 at 10:05 AM / IP Logged
in the owners manual it states 2 ohm load  350 x 1  .   the amp has two channels does this mean it has 350 watts per channel or  350 watts for both channels?   this is a mono amp .  and is it better to wire to a lower ohm rating or hire.
SoundAudio
Copper - Posts: 242
Posted: June 17, 2005 at 10:14 AM / IP Logged
The amp only has one channel.  It has two sets of speaker terminals so you can cleanly connect two woofers to it in parallel.  The rating given is 350 X1 @2 ohm, therefore witha 2 ohm load the amplifier will put out 350 watts.   The lower the impedence rating the better.  I believe it is stable to 1 ohm.  Good Luck!
Nodestiny
Copper - Posts: 85
Posted: June 17, 2005 at 10:33 AM / IP Logged
correct. At 1 ohm it is rated 1000 watts... realisticly its more like 900 watts, unless you have a solid electrical system. Both + are connected internaly, and both -s as well. So just get er down to 1 ohm and youll be pullin some good power then. I have had these amps down to 1/2 ohm without a problem (other than they get very hot.)
04 dodge neon SXT
(2) Oz Audio Matrix Elite 12"s sealed in 4 cube fiberglass enclosure, powered by HiFonics BX1605D
Oz Audio Matrix 180cs 6.5" component set power by HiFonics ZX4000
dmkicker
Member - Posts: 6
Posted: June 17, 2005 at 10:40 AM / IP Logged
thank you for the info
