LOC in 97 camry
rollinstyle
Posted: August 07, 2005 at 10:53 PM / IP Logged
I intsalled an amp in my sisters 97 camry XLE today but after finishing everything the amp wouldn't power up.  I wired the LOC into the harness that plugs into the factory amp.  Is that right?  Do I have to wire it into the front and rear speakers or one or the other?  I wired the remote lead into what is supposed to be the ignition wire, going by the wiring diagram provided by this site.  Thanks for any help.
ss-installer
Silver - Posts: 444
Posted: August 07, 2005 at 11:01 PM / IP Logged
the last camry i did was different than the database diagram. when installing anything to a factory radio i use an adapter plug to trace the wires on the factory plug. its a little easier for me since i work at a shop and we have all the plugs but it takes all the guess work out of wireing (usually).
geepherder
Platinum - Posts: 3,668
Posted: August 08, 2005 at 12:22 PM / IP Logged
Yes, referencing wires off an adapter plug will save you plenty of time.  Even if you don't have one, you can still test the wires with a multimeter to confirm their function.
Hornshockey
Silver - Posts: 520
Posted: August 08, 2005 at 11:21 PM / IP Logged
The LOC shouldn't have anything to do with the amp not powering up;  double check your remote wire connection, and your grounding point.
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
rollinstyle
Posted: August 09, 2005 at 9:34 AM / IP Logged
I am also putting in a CD changer and when I hooked it up the unit powered on and ejected the cartridge but the control screen wouldn't turn on.  Maybe I hooked the ignition power into the wrong wire?  I spliced it into the gray wire on the factory amp harness. Thanks.
