multi batteries
Reeceddogg
Copper - Posts: 331
Posted: October 29, 2005 at 6:53 PM / IP Logged
i done many searches on here and just want to make sure that when running multiple batteries and isolator isn't necessary, right?
Alpine Guy
Platinum - Posts: 2,478
Posted: October 29, 2005 at 6:59 PM / IP Logged
right, as long as you have 2 of the exact same battery's off the exact same assembly line during the same time period.
bajaclawz71
Member - Posts: 45
Posted: October 30, 2005 at 12:53 AM / IP Logged
Also if you are trying to use it as a backup battery than you will want to isolate them.
KarTuneMan
Platinum - Posts: 7,056
Posted: October 30, 2005 at 1:13 AM / IP Logged
Just get an isolator......simple. Eliminate the potential for a problem.  Come-on.........
Mad Scientists
Silver - Posts: 380
Posted: October 30, 2005 at 7:56 PM / IP Logged
If you are using a second battery to run the system with the engine off, then you'd need an isolator. If you believe you need two batteries when the engine is running, then you'd need to try to match the batteries.. but I'd be curious why you'd need two with the engine running.
Jim
Reeceddogg
Copper - Posts: 331
Posted: October 30, 2005 at 9:40 PM / IP Logged
I'm not worried about playing with the system off, i can just start the car. and since i'm buying the batteries at the same time i hope they are exactly the same
Reeceddogg
Copper - Posts: 331
Posted: October 30, 2005 at 9:44 PM / IP Logged
sorry that's playing with the car off
Mad Scientists
Silver - Posts: 380
Posted: November 01, 2005 at 6:07 PM / IP Logged
Why do you think you need multiple batteries? What are you hoping to accomplish?
Jim
Reeceddogg
Copper - Posts: 331
Posted: November 01, 2005 at 8:27 PM / IP Logged
jus want to make sure i have plenty of power for my system and it doesn't look like just any single battery will do it
bajaclawz71
Member - Posts: 45
Posted: November 01, 2005 at 11:53 PM / IP Logged
Well the only time that you would be running your system off of the batteries is when the vehicle is off.  A second battery won't do anything for you.  You will need a higher output alternator if you run into too much current draw from your stereo.  Just as a side note a capacitor won't do much if anything either.
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
