1998 S10, new deck
rones
Member - Posts: 16
Posted: November 17, 2005 at 10:26 PM / IP Logged
I need to know how to hook up a new deck to a 98 s10. the factory stereo was ripped out along with the harness so i need the wiring diagram. The truck has the feature that the radio does not shut off until the door opens and i need help with this. Any help would be appreciated.
menace2sobriety
Silver - Posts: 394
Posted: November 18, 2005 at 12:56 AM / IP Logged
Stereo i could not find it for the s-10 this is for the gmc. it should br the same. but check it out.
daze
Copper - Posts: 112
Posted: November 18, 2005 at 3:52 PM / IP Logged
if the factory stereo turned off when the door was opened, then there probley is no 12v accessory behind there. So you would have to run your own. You could always us a meter to test the lines, battery to pop the speakers, or even take the speakers out and see what colors are there. Then pick up a factory harnes from a local auto shop or junkyard.
Thats my 2 cents.... take it for what its worth!
Nothing can replace experience
1998 S10, new deck -- posted image.
kirktcashalini
Silver - Posts: 492
Posted: November 21, 2005 at 1:16 PM / IP Logged
There is a 12V accessory behind the unit. It goes off when you open the doors as well. I have a 99 blazer, and when i shut her off it still plays music even with the subs until i open the doors. I believe the particular color for 12V accessory is yellow. NOT blue... ;-)
