Kicker competition C18a 8 Ohm info?
ocboy79
Member - Posts: 26
Posted: December 03, 2005 at 12:00 PM / IP Logged
i just got this speaker from a garage sale. it a kicker but the only identification on it says " competition C18a 8 Ohm" could someone please help out with a little info on the speaker. also if anybody knows box dimensions for spl and what kind of amp would be good to push it. thanxs
panasonic-8300
16- pioneer ts-w250r
boston 6x9
menace2sobriety
Silver - Posts: 394
Posted: December 03, 2005 at 2:58 PM / IP Logged
sell it. the box you will need for that is going to be big. they like ported boxes. and the amp get a 800 watt bridged at 4 ohms. so when you hook that 8 ohm up to the amp it will get 400 watts. what do you you plan on putting this in?  the box will not fit in a small car.
ocboy79
Member - Posts: 26
Posted: December 04, 2005 at 11:52 PM / IP Logged
by bridging do you mean run a pos. to one channel and a neg. to the other? the sub is a single voice coil but it has two pos. and 2 neg. connections. so could i run both channels on the amp to the sub?
panasonic-8300
boston 6x9
dwarren
Posted: December 05, 2005 at 12:00 AM / IP Logged
Use it as a home theater subKicker competition C18a 8 Ohm info? -- posted image.
ocboy79
Member - Posts: 26
Posted: December 05, 2005 at 12:04 AM / IP Logged
i would but i already have 4 12'S for my theater system
panasonic-8300
boston 6x9
menace2sobriety
Silver - Posts: 394
Posted: December 05, 2005 at 12:36 AM / IP Logged
bridged i mean run it mono. if you use a class a/b 2 channel amp comined the L&R channels together. or just buy a class d amp rated at 800 watts @ 4ohms. what is this sub going in? and dont run L+L- and R+R-. it will not work right. a 2 channel amp will show you how to bridge the amp under the speaker terminals. a class d will be you best bet.  i hope you have a station wagon for that sub.
