building sealed box for 2 woofers?
kirktcashalini
Silver - Posts: 492
Posted: December 21, 2005 at 6:33 PM / IP Logged
when building a sealed box for 2 woofers, i want both to have 1.05 cubes each, so 2.1 total, should i have them in one air space, or have a divider between the subs. I have seen both, just wanted to know if anyone knew or had opinions. thanks... sq setup, not spl, if that makes a difference.
darthness
Copper - Posts: 136
Posted: December 21, 2005 at 6:38 PM / IP Logged
you sohuld be safe with 1 chamber. it shouldn't make that huge of a difference with the smallerish boxes.
kirktcashalini
Silver - Posts: 492
Posted: December 21, 2005 at 6:52 PM / IP Logged
define safe? because it doesnt matter to me, just means i add 3/4" on overall length. i want whatevers best.
stevdart
Platinum - Posts: 5,816
Posted: December 21, 2005 at 8:36 PM / IP Logged
The same either way.  Build it the way that suits you best.  For myself, and I gather you too, putting the extra time, effort and materials into it by building a center baffle is the way I would tend to go.  The divider will add support to the weakest section of the box.
kirktcashalini
Silver - Posts: 492
Posted: December 21, 2005 at 9:24 PM / IP Logged
if stedvart says it, it must be true... hehe. Doing the center devide. PERIOD. thanks
