FMT-40D transmitter does not power?
pioneer212
Member - Posts: 17
Posted: December 24, 2005 at 1:27 PM / IP Logged
OK, I hooked up the Farenhiet FMT-40D wireless FM transmitter to a gorund and positive and everything was working fine, I turned the car off and turned it back on and the unit did not power up again. I checked the fuse which was fine, but did replace it to test, but no luck. I opened the unit up and made sure that power was reaching the board inside, and tested it with a voltmeter and the power was reaching the circuit board were the + and - were soldered to, but it would still not power up. Can someone please help me?
DYohn
Moderator - Posts: 10,741
Posted: December 24, 2005 at 1:47 PM / IP Logged
I don't know anything about that unit, but in general if you have something connected correctly and it stops working, it may be defective.  Take it back for warranty replacement.
Friday, November 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
