Memory, Constant Power Wire, 97 Mirage
jdkoppel
Member - Posts: 14
Posted: January 22, 2006 at 1:51 AM / IP Logged
my head deck resets itself evry time the ignigtin is turned off. After taking the headdeck out i cant find which to wires to connect as the memory wire. I have a pioneer deck and a mitsi mirage 97.
would really appreciate any help.
pss5075104
Copper - Posts: 144
Posted: January 22, 2006 at 9:46 AM / IP Logged
i am going to assume that the deck was hard wired. Take the yellow off the pioneer deck to the RED / black from the cars wiring harness.
D
MECP First Class Certified Installer.
Nothing is impossable, it's just more expensive.
jdkoppel
Member - Posts: 14
Posted: January 22, 2006 at 4:50 PM / IP Logged
ok and do what with the blue wire (from the harness) that was connected to the yellow?
cheers
nstaller36695
Copper - Posts: 106
Posted: January 23, 2006 at 2:22 AM / IP Logged
ok first the blue wire is output only. u need to read the manual and get a proper diagram for wire color and there isnt a ground wire on the harness so ground the black wire from the radio to metal and make sure u test ground with a meter but the red wire is for ignition and yellow is for memory which should be 12 volts with the key on or off.
the best part of a job is seeing the bumper get smaller over the horizon
