dual 6 ohm subs, to 4 ohm? 4 channel amp
crzy4507
Member - Posts: 12
Posted: January 24, 2006 at 1:16 PM / IP Logged
I recently got a gopod deal on a pair of Audiobahn subs... ALUM12N... 12 inch DVC subs... From what i know, they can from 3ohm or 12 ohm.... all i have is a 4 channel 4ohm amp.... im guessing im gonna need to get a new one... but i dont know what kind or any possible ways to set it up... still kind of an amatur at this.. any help... if possible a complete list would be GREAT... thanks
the12volt
Administrator - Posts: 3,959
Posted: January 24, 2006 at 1:20 PM / IP Logged
You can view wiring options here.
dual 6 ohm subs, to 4 ohm?  4 channel amp -- posted image. the12volt • Support the12volt.com
stevdart
Platinum - Posts: 5,816
Posted: January 24, 2006 at 3:35 PM / IP Logged
Now you need to find a good deal on a mono amp.  Put those subs in a small sealed enclosure and give them about 800-900 Audiobahn watts apiece.  Using something like this.  With those subs wired parallel/parallel you would be putting a 1.33 ohm load on the amp.  Save your four channel amp for the interior speakers.
Note to who is paying attention:  compare apples to apples.  ;)
