Clarion VRX 8271 Wiring Diagram
gavin9797
Copper - Posts: 106
Posted: January 31, 2006 at 10:14 PM / IP Logged
I have a VRX 8271, but have lost the install manual. I took the deck about 4-5 years ago and am thinking of installin it again.
Does anyone have the wiring diagram/color codes for this unit?
geepherder
Platinum - Posts: 3,668
Posted: February 01, 2006 at 8:39 PM / IP Logged
Probably: https://www.the12volt.com/request/request2.asp
gavin9797
Copper - Posts: 106
Posted: February 01, 2006 at 10:31 PM / IP Logged
Thank you for the link, I just have a feeling there is something different with this deck because it has the motorized monitor?...I'll double check my harness though...it may come back to me as I go to install it.
geepherder
Posted: February 02, 2006 at 12:48 PM / IP Logged
The motorized monitor does not make a difference as long as it's not much more than 10 years old or so- or a pre-99 Pioneer.  Usually the only wire color that's different from brand to brand is the mute wire, but other than that, the colors should match. Many Clarion units have two yellow wires, you just simply connect them together.
gavin9797
Copper - Posts: 106
Posted: February 02, 2006 at 7:21 PM / IP Logged
Right on thanks alot!
gavin9797
Copper - Posts: 106
Posted: February 06, 2006 at 7:29 PM / IP Logged
OK...I found some mystery wires. Everything in the harness is as it should be. But on the back of the deck there is...
White w/ red stripe (single wire no mate)
Orange
Orange w/ white stripe - (maybe these are illum power, and illum ground?)
geepherder
Posted: February 07, 2006 at 8:23 PM / IP Logged
WHITE/ red may be a phone mute- different brands use different colors as there is no standard for this wire.  Orange and ORANGE / white are illumination/dimmer as you asked.  These wires are not required for install, but if it's there in both harnesses, you can hook it up if you want.
gavin9797
Copper - Posts: 106
Posted: February 07, 2006 at 9:13 PM / IP Logged
Thanks again.
the orange is for parking brake.
the ORANGE / white is for illumination
the WHITE/ red is for rear vision camera control
there are 2 ground leads
the yellow rca is for rear vision camera.
