Need opinion for my set up
my530i
Posted: February 07, 2006 at 12:35 PM / IP Logged
Hi,
I'm interested in the following amps:
1. Infinity Car Audio REF5761A - Infinity 560 Watt 6-Channel Power Amplifier RMS Power @ 4 Ohms:60W x 4 + 107W x 2
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2960
2. JBL Car Audio GTO755.6 - JBL 6 Ch 560 Watts Power Amplifier RMS Power @ 4 Ohms:60W x 4 + 107W x 2
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3126
3. JL Audio e6450 - JL Audio 6 Ch 450 Watt Amplifier
45W RMS x 6 @ 4 ohm (12.5V);
to drive:
Rear: 2 x MB Quart RVF 210
Under front seat left and right 40W OEM subwoofer
Would you guy give me your opinions?
My car is 2004 BMW 530i which has OEM sound system configuration as follows (Hi-Fi sound system 10 speakers):
Front Left: 4" mid-range + 1" tweeter
Front Right: 4" mid-range + 1" tweeter
Rear Left: 4" mid-range + 1" tweeter
Rear Right: 4" mid-range + 1" tweeter
Under front seat (left): 8" OEM shallow mount subwoofer (~40W)
Under front seat (right): 8" OEM shawllow mount subwoofer (~40W)
I want to upgrade my sound system is good anough to listen to music with as much detail as I can. I don't want to rattle my license plate :)
Thanks in advance.
DYohn
Platinum - Posts: 10,741
Posted: February 07, 2006 at 2:02 PM / IP Logged
My choice among those amps would be JBL.
forbidden
Platinum - Posts: 5,354
Posted: February 07, 2006 at 2:13 PM / IP Logged
Check on those Quart speakers, if they say made in China on them instead of made in Germany, find new speakers as the made in China ones sound like arse by comparison to the good German models. If I am correct both the JBL and Infinity amps are going to be remarkably similar as both companies are owned by Harmon.
kfr01
Gold - Posts: 2,121
Posted: February 07, 2006 at 2:23 PM / IP Logged
my530i wrote:
Hi,
to drive:
Thanks in advance.
What would I do?
1) Disconnect all your factory speakers.  Forget about using them.
2) Get some kick panels to house some high quality 6.5" components.
3) Buy a single high quality 10" subwoofer and small sealed box for the trunk.
4) Buy a 4-channel bridgable amplifier.  Run the front two channels to the components, bridge the rear channels to the subwoofer.
5) Have all of the above professionally installed.
6) Buy a bridgable 4-channel amplifier with flexible crossover settings for the front and rear channels.
7) Use a high pass crossover on the front channels.  80hz is a good starting point.
8) Use a low pass crossover on the rear channels.  80hz is a good starting point.
In my opinion this is the fastest and least expensive path to an excellent sound quality system.
Here are some benefits of using a kick panel location:
http://www.crutchfieldadvisor.com/S-ev2voYpmUbT/learningcenter/car/speakers_imaging_soundstage.html
Others include being able to use larger drivers that can handle more bass and bringing the speakers on axis.
New Project: 2003 Pathfinder
stevdart
Platinum - Posts: 5,816
Posted: February 07, 2006 at 6:56 PM / IP Logged
I would use a high pass on the rears just the same as the fronts.  The speakers aren't capable of sub bass freqs.
kfr01
Gold - Posts: 2,121
Posted: February 07, 2006 at 7:18 PM / IP Logged
Right... low pass on the rear channels running the 10" subwoofer I recommend he use instead of the stock 8" drivers.
my530i
Posted: February 07, 2006 at 7:28 PM / IP Logged
If I replace the two front seat sub, I'd replace them with Earthquake SWS-8" shallow mount 150W RMS
http://www.amazon.com/gp/product/B000AMI2HG/ref=sr_11_1/102-2217042-0908919?%5Fencoding=UTF8
According to JL, JBL and Infinity amp specs, JL is too wimpy for Earthquake SWS-8 150W RMS, and JBL/Infinity shoud be OK to drive it. However, JBL/Infinity don't have good SNR, THD, etc. compared to JL.
What's your opinion?
stevdart
Posted: February 07, 2006 at 7:29 PM / IP Logged
Need opinion for my set up -- posted image.  Ahhh, I see now....thought that might have been a typo.
stevdart
Posted: February 07, 2006 at 7:33 PM / IP Logged
To drive a 150 watt continuous power handling sub....who's too wimpy??
my530i
Posted: February 07, 2006 at 7:44 PM / IP Logged
JL Audio amp is too wimpy to drive 4 MB quart set + 2 Earthquake SWS-8, according to the spec:
Earthquake SWS-8 is single coil 4-ohm.
MB quart:  40 - 90 W RMS.
For MB Quart, I think the amp is OK to drive those, but for Earthquake, I'm afraid it's too much for JL Audio e6450 - JL Audio 6 Ch 450 Watt Amplifier ?
