mutang mach360 turn on pop
carstereoman
Member - Posts: 48
Posted: February 21, 2006 at 4:38 PM / IP Logged
Got a 2000 mustang w/ the mach 360 system. I put in an aftermarket radio and when you first turn on the radio it makes a loud pop through all of the speakers. I put in a new ground and tried a new radio to no avail. It does have an amp and sub hooked up. Could it have something to do with the amp turn-on wire? Anybody got any suggestions? Thanks!
Hornshockey
Silver - Posts: 520
Posted: February 21, 2006 at 4:41 PM / IP Logged
yep, you need a 1.5K ohm resistor on the turn-on lead. Ford factory lead uses 5V instead of the aftermaket 12V.
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
