hiding 0 gauge wire?
wanabecarguy
Posted: February 26, 2006 at 1:05 PM / IP Logged
i am running 0gauge but i am trying to figure out what is the best way to hide it?
kirktcashalini
Silver - Posts: 492
Posted: February 26, 2006 at 2:14 PM / IP Logged
haha... might just be me, but i think a little more info is needed... Type of car, how many amps, you know......
darthness
Copper - Posts: 136
Posted: February 26, 2006 at 8:25 PM / IP Logged
same way you hid any other gauge wire?
impaladad
Member - Posts: 14
Posted: February 26, 2006 at 10:26 PM / IP Logged
I am not sure what the technical name is for this product, but is similar to the padding under the carpet of most cars. I used to order it from select products, but I am sure it is available elswhere. Anyway it is a padding about 1" thick. I wouldcut strips of it, and place them on either side of the wire, and it helps disquise the usual lump under the carpet associated with heavy gauge wires. If you're working under the hood careful planning goes a long way!
willdkartunes
Copper - Posts: 250
Posted: February 27, 2006 at 12:18 AM / IP Logged
A lot more info on this one would be a big help....
jeosnh
Member - Posts: 12
Posted: February 27, 2006 at 2:17 PM / IP Logged
Ok, I have never done this for the amp power cable on any of my daily drivers, but on my '66 Nova I relocated the battery to the trunk and I just ran the cable under the vehicle. The thing is that this car isn't driven in any inclimate weather and is by no means a daily driver, also the cable is for the most part out of harms way. Is this something that most of you frown upon or do other people do this?
forbidden
Platinum - Posts: 5,354
Posted: February 27, 2006 at 2:25 PM / IP Logged
It is alright to do this provided that you have properly secured the cable (don't want it to chaff) and protected it (don't want it to snag). It also is going to need a fuse at both ends of this cable to protect the vehicle from a fire incase the power wire does somehow short out.
godblessdremil
Silver - Posts: 273
Posted: February 27, 2006 at 4:40 PM / IP Logged
Eather i get some padding to put around it. Or you can run it underneath your car(This option isn't really smart unless it done carefully, and the wire prepared for the abuse its going to take..
