formula to calculate wattage?
dubb
Copper - Posts: 52
Posted: March 08, 2006 at 6:50 PM / IP Logged
whats that formula to find out exactly how many watts an amp pushes amps..something bout the volts received, fuse ratings..blah..
2005 Ford 500 SEL. 3 Kicker CVR 15"s. 2000 watt Quantum Audio AMP.
coppellstereo
Silver - Posts: 785
Posted: March 08, 2006 at 6:56 PM / IP Logged
https://www.the12volt.com/ohm/page2.asp#power
KPierson
Platinum - Posts: 3,527
Posted: March 08, 2006 at 8:14 PM / IP Logged
Keep in mind that if you are trying to calculate the power of an amp you'll need to know the effienciency of the amp in question.  Also, actual current draw is much more important then fuse size.  Just multiplying voltage by current will give you an extremely inflated value of actual real power.
Kevin Pierson
willdkartunes
Copper - Posts: 250
Posted: March 08, 2006 at 9:41 PM / IP Logged
The current draw of an amplifier is usually much lower than the fuse rating on it right? How do you know how much lower it is?
KPierson
Posted: March 08, 2006 at 10:43 PM / IP Logged
The only real way to know would be to use a current meter.  However, most current meters aren't big enough to measure above ~20A.
Kevin Pierson
willdkartunes
Copper - Posts: 250
Posted: March 09, 2006 at 12:18 AM / IP Logged
There must be a way .... I'll look around for this one. Unless someone else can shed some light on this subject for us ....
Steven Kephart
Platinum - Posts: 1,737
Platinum spaceThis member has been recognized as an authority in Mobile Audio and Video. Click here for more info.spaceThis member consistently provides reliable informationspace
Posted: March 09, 2006 at 2:54 AM / IP Logged
If you want to do it right, then you will need an osciloscope and a resistive load.
jeffchilcott
Platinum - Posts: 2,483
Posted: March 09, 2006 at 3:00 AM / IP Logged
you can come very close with a clamp style fluke meter or similar and a DMM      measure the AC voltage and AC current coming thru your speaker leads
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Steven Kephart
Posted: March 09, 2006 at 3:55 AM / IP Logged
The down side to that is he won't know the exact point where the amplifier is clipping.  But it is probably the next best way to do it.
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
