02 trailblazer w/bose
mutt69
Member - Posts: 8
Posted: March 18, 2006 at 4:20 PM / IP Logged
Hi i got a 02trailblazer ext W/bose an onstar.I ran the ign wire and pulled the amp . all work exept dash lights any ideals would be great.thanks in advance
Live loud and fast or die slow and silent.        Noize Pollution C.C
Fastlearner
Silver - Posts: 346
Posted: March 19, 2006 at 12:55 AM / IP Logged
What do you need advice on. You really didn't state anything.
mutt69
Member - Posts: 8
Posted: March 19, 2006 at 2:49 PM / IP Logged
sorry for bing vague i wanted to know if the foactory bose amp was some how wired into the dash lights.or if someone could point me toward a wiring diagram of the bose system
Fastlearner
Silver - Posts: 346
Posted: March 19, 2006 at 8:48 PM / IP Logged
I don't believe the amp is wired with the light circuit however the radio is. Did you change your deck. Check the fuses both inside and outside the vehicle.
mutt69
Member - Posts: 8
Posted: March 20, 2006 at 5:03 AM / IP Logged
ya put a clarion touch screen dvd in . thanks for the in put .should have opted for the relocation harnass .i guess we learn from our mistakes
kgerry
Platinum - Posts: 3,455
Posted: March 20, 2006 at 9:36 AM / IP Logged
check your fuses, you may have shorted something during the install... if the same fuse blows again pull the Clarion and look for a wire touching metal behind it or double check to make sure you dont have the illumination wire mistaken for a speaker wire.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
