2003 Nissan Frontier Speaker help
Thinkster
Copper - Posts: 94
Posted: January 02, 2003 at 2:57 PM / IP Logged
I want to change the original factory speakers which are 2 Ohm 15 Watt, 6 3/4" speakers that have an integrated spacer/molding and use some Pioneer 3-way 6 1/2"  but the problem is that if I mount the pioneer speakers,  there is no longer clearance for the window to roll all the way down and if I use washers to space it enough,  there's too much gap and the speakers sound like crap compared to the original factory speakers.    Is there some sort of adaptor plate or spacer or other solution I can use?
brianh
Silver - Posts: 518
Posted: January 02, 2003 at 4:19 PM / IP Logged
How much clearance do you need?  If you do not need more than a 1/2 inch or so, get some MDF board and cut trim rings to stand your speaker away from the door.     Brian
Thinkster
Copper - Posts: 94
Posted: January 03, 2003 at 3:04 AM / IP Logged
I would say I need about 1/2 inch or so.   I would prefer to do it with something pre-fabbed if there is such a thing.
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
