4 ch vs 5 ch amp
wagner
Posted: April 27, 2006 at 11:19 AM / IP Logged
I am in the process to get an amp but i was offered a 5 ch amp,  I have been doing research but i dont see too many things about 5 ch amps and if they work.
The equilizer i got is:
Kenwood KGC-6042A
and the head unit: Kenwood Excelon KDC-X890
This will be installed in a Opel Astra G, 2004
I am planning to install 2 set of :
Boston Acoustics SX50
5-1/4" component speaker system
Sensitivity 90 dB
Frequency Response 58 - 20k Hz
RMS Power Range (Watts) 2-65
Peak Power Handling (Watts) 200
Impedance (Ohms) 4
Top-mount Depth (Inches) 2 1/8
Bottom-mount Depth (Inches) N/A
Cutout Diameter or Length (inches) 4 9/16
and a sub
Sony XS-L123P5
12" 4-ohm subwoofer
Impedance 4 ohms
Sensitivity 89dB
Frequency Response 18 - 2k Hz
RMS Power Range (Watts) 90-380
Peak Power Handling (Watts) 1300
Vas (liters) 86.7
Fs (Hz) 24.8
Qts 0.37
Xmax (millimeters) 5.7
What would be your recommendation in the type of amp or amps I should get?
Wagner
Stop dreaming ur life!
start living ur dream!!
xtremej
Gold - Posts: 1,440
Posted: April 27, 2006 at 11:30 AM / IP Logged
Judging by the power requirements a 5 channel would be suitable. Consider that some 5 channels are quite large though.  The 2 I would recomend (do to personal experience) are the concept cca -664 or one made by memphis i forgot the model number. Both worked well.  the concept gives 60x4 and 200x1. roughly 11"x17". its at this link.
forbidden
Platinum - Posts: 5,354
Posted: April 27, 2006 at 11:33 AM / IP Logged
I agree with Jeremy. For your application, a 5 channel amp would work great. The Concept amp is a great little amplifier, if you can find a Eclipse PA5532, it would be a good step up from the Concept.
kgerry
Platinum - Posts: 3,455
Posted: April 27, 2006 at 5:41 PM / IP Logged
i concur that a 5 channel amp would be the most efficient solution... i have used a few Directed D2205's lately in this situation with success....
my only fear ( bad memories of Soundstream 5 channels grenading on me) is that if you overdrive and blow the sub output stage you lose the whole system....  whereas with a dedicated sub amp and satellite amp you dont have the same potential problem.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
