Deck Preouts stopped working
JdM xplod b01
Copper - Posts: 73
Posted: May 07, 2006 at 2:41 AM / IP Logged
My preout for my amp just stopped sendin a signal to my amp. It a kenwood kdc-mp4028. I reseted the deck, it worked for a min then stopped again. Wha can i do to fix it? Is there a way to fix it?
Pioneer Premier TS-w3004spl, Bass Slammer vented, Kenwood KDC MP-4028, and a KAC-9152d.
mad550
Copper - Posts: 201
Posted: May 07, 2006 at 3:13 AM / IP Logged
Is it the deck? Have you checked for ac voltage on the pre outs? Or are you just unplugging then plugging back in.When you check for voltage make sure nothing is connected. But in saying that Kenwood decks are notorious for dry solder joints on the main circuit board where the pre outs are, if this is the case you'll need to srtip the unit down, pull out the board and reflow the joints and re assemble.  When I was still doing repairs I used to get 8-10 units a week with the same problem.
WOW Sight and Sound
Maroochydore
Nothing is impossible!
Do it right the first time or don't do it at all.
JdM xplod b01
Copper - Posts: 73
Posted: May 08, 2006 at 12:18 AM / IP Logged
So i just add some solder to the pre out joint? Can u please post a pic to show me how and wha part to do it, it would help me out a lot. Thanks.
forbidden
Platinum - Posts: 5,354
Posted: May 08, 2006 at 12:24 AM / IP Logged
Hold up there dude. Consider that you might be taking apart a cd player and the problem might not be there....you just fixed (or damaged) the cd player for nothing. First thing I would do is run a new rca cable over the seats from the cd to the amp and retest to see if it is the cd or something else.
mad550
Copper - Posts: 201
Posted: May 08, 2006 at 3:54 AM / IP Logged
After checking all other possibilities then take it to a repair agent it might sound easy but it's not.
WOW Sight and Sound
Maroochydore
JdM xplod b01
Copper - Posts: 73
Posted: May 09, 2006 at 7:34 PM / IP Logged
Well i put in a panasonic deck and same problem. Then i ran a tv rca to the amp and still nothing. Then i ran out of ideas and gave up. . . but when i put my amp in my friend's car it works .Deck Preouts stopped working -- posted image. I also tested the sub and it works. I need help! Anyone?
mad550
Copper - Posts: 201
Posted: May 09, 2006 at 7:48 PM / IP Logged
In that case the problem has to be in the wiring, check everything like voltage, shorts or breaks in the speaker wiring, remote wire, are you getting a good earth? and so.
WOW Sight and Sound
Maroochydore
kirktcashalini
Silver - Posts: 492
Posted: May 09, 2006 at 8:16 PM / IP Logged
yeah sounds confusing, because you say everything works, amp and subs...
gotta love you austrailians.. earth Deck Preouts stopped working -- posted image. umm, may sound retarded, but does your head unit have a mode where it will disable the preouts?
JdM xplod b01
Copper - Posts: 73
Posted: May 09, 2006 at 8:28 PM / IP Logged
I can turn my subwoofer preout off, but im sure it is on. Also tv rcas work the same as car rcas right?
mad550
Copper - Posts: 201
Posted: May 09, 2006 at 9:34 PM / IP Logged
LOL earth ground same sh*t different smell
I wouldn't be surprised if the preouts are disabled or turned down LOLDeck Preouts stopped working -- posted image.
WOW Sight and Sound
Maroochydore
