How to Wire it? Audiobahn AW1000Q
percyv143
Copper - Posts: 77
Posted: May 26, 2006 at 10:42 PM / IP Logged
Hi. I just got this woofer box with an amplifier Boss 535 800W and an Audiobahn AW1000Q. I need help how to wire the speaker to the amp. The speaker has 2 sets of connectors on each side. Pictures attached. I appreciate the help. Thanks.
How to Wire it? Audiobahn AW1000Q -- posted image.
dwarren
Posted: May 26, 2006 at 10:51 PM / IP Logged
It would be very helpful if you were to give the impedance(ohms) of each coil on that woofer, and the power rating on the amp
percyv143
Copper - Posts: 77
Posted: May 26, 2006 at 10:58 PM / IP Logged
The speaker has 4 ohms each coil at RMS 600W / 1200W Peak. When I opened the sub box there were 2 sets of wires. 1 set on each side but only 1 set was connected to the amp and the other was disconnected. Thanks.
dwarren
Posted: May 26, 2006 at 11:13 PM / IP Logged
Assuming that amp is 2 ohm stable, here is how you will wire the woofer. Again, I am not sure if that amp is bridgeable to 2 ohms. Please list the specs on the amp if possible I don't want to be responsible for broken equipment.
percyv143
Copper - Posts: 77
Posted: May 26, 2006 at 11:17 PM / IP Logged
I got this from their site.
    * Optimized for Maximum Sound Quality / SPL
    * PHAT 2” Foam Surround
    * 120 oz. Magnet
    * Non-Pressed, Non-Transfer Paper Cone
    * KM3 Coated Cone for Low Cone Distortion
    * Bolt-Tight Cast Flame Basket
    * Multi-Connect Lug-Lock Terminals
    * Mounting Depth: 5”
    * Hole Cutout: 9 1/4”
    * Outer Diameter: 10 7/8”
Subwoofer Specifications
    * Size: 10 inch
    * Rec. Sealed Box Dims: .25 - .75 cu.ft.
    * Rec. Ported Box Dims: .65 - 2.35 cu.ft
    * Free Air Usage: not recommended
    * Sensitivity: 91.1 dB
    * Frequency Response: 23-500 Hz
    * Recommended RMS Power: 600W
    * Peak Power Handling: 1200W
    * Impedance: dual 4 ohms subwoofer wiring options
