Wiring 4 channel amp
soldjaboy69
Posted: May 29, 2006 at 1:43 PM / IP Logged
Hey everybody. I have a 1000 watt 4 channel amp. on the amp channel 1 and 2 have their own set of rca plugs and channel 3 and 4 have their own set. how do i wire everything up to where i can use all 4 channels on the amp when i only have 1 set of rca output plugs from my headunit. right now im only able to use 2
killer sonata
Silver - Posts: 718
Posted: May 29, 2006 at 2:05 PM / IP Logged
First off, what is the 4 channel amp being used for. I am assuming for 4 door speakers? Second, is the 1 output from your deck a full range output or non-fader only?
soldjaboy69
Posted: May 29, 2006 at 2:19 PM / IP Logged
the amp is being used to push my subs. i was wanting to bridge the subs on the 4 channels. and i don't know about the output from the deck
DYohn
Platinum - Posts: 10,741
Posted: May 29, 2006 at 2:52 PM / IP Logged
Use 2 Y-cables.
In general a 4-channel amp is not the best solution for subs, but it can certainly be used.  Make sure your impedance load on each bridged set of outputs is no less than 4-ohms and set your gains and LP crossovers properly.
soldjaboy69
Posted: May 29, 2006 at 2:57 PM / IP Logged
i tried using 2 y-cables but it lost power when i did it didnt sound as good
DYohn
Posted: May 29, 2006 at 3:07 PM / IP Logged
Yep, that sounds about right.  Unless you want to buy a good line driver that can create multiple outputs from one, or replace the amp with a proper subwoofer amp, this is the only thing you can do.  Install the Y-cables and then properly reset your gains.
soldjaboy69
Posted: May 29, 2006 at 4:16 PM / IP Logged
if i wanted to use it for my door speakers how would i wire it?
killer sonata
Silver - Posts: 718
Posted: May 29, 2006 at 4:18 PM / IP Logged
Sounds to me like you would have to upgrade your cd player first. You should get one with 3 sets of rca outputs. 1 for fronts, 1 for rears, and 1 for subs.  You could use signal sensing to the amp but it just doesnt ever sound all that great.
soldjaboy69
Posted: May 29, 2006 at 4:22 PM / IP Logged
ok thank you for tha help
