1996 Chevy Tahoe 6 speaker system
hereinak
Posted: May 31, 2006 at 12:39 AM / IP Logged
I Need to know if anyone has a diagram or information on installing a new head unit in this rig I can get the front speakers working but not all of the rear.
Patrick
geepherder
Platinum - Posts: 3,668
Posted: May 31, 2006 at 6:13 AM / IP Logged
This usually is no concern because you should want most of your sound to come from the front, but try powering up the factory amp turn on lead in the harness.  This wire should be pink in the factory radio harness and may be labelled as power antenna on the Metra harness.
hereinak
Posted: May 31, 2006 at 8:51 PM / IP Logged
That is true but it has two 6.5's in the rear doors I would like to use, The 4X10's in the roof seem to be a wast of time.
Patrick
cntrylvr79
Silver - Posts: 582
Posted: May 31, 2006 at 9:40 PM / IP Logged
As was stated before there's a pink wire that must be hooked up to the amp turn on of the after market radio.  It may not be in the standard harness though.  If there were 2 harnesses plugged into the stock radio, then it'll be in the smaller plug.
Cause I'm So white and nerdy...
First Class Certi-fried installer
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
