What kind of box in a SUV?
arkansasboy
Member - Posts: 35
Posted: June 22, 2006 at 11:14 AM / IP Logged
I have two 15" Soundstream 15's and a 2400watt Fosgate amp and needless to say it is loud! Right now I have them in a seald box with no wall, it is the perfect amount of airspace for them aswell and it rattles your chest (measured 144 db's). If I were to put it in a vented box or a ported box, do you think it would sound better? Please give any suggestions
Dan Tha Man
forbidden
Platinum - Posts: 5,354
Posted: June 22, 2006 at 11:26 AM / IP Logged
Put them into a properly constructed and ported enclosure. Then they will come alive. If you also paint the box green, you will get another 2db out of it, 3db if the thing is camo color to get rid of the hot spots that soak up bass response.
aznboi3644
Gold - Posts: 2,600
Posted: June 22, 2006 at 7:10 PM / IP Logged
LOL...I painted my box same color as my truck...navy and gained 3db.
arkansasboy
Member - Posts: 35
Posted: June 22, 2006 at 7:40 PM / IP Logged
o yeah? so hey maybe if I paint it tan i'll gain 3 db's? sounds good to me! anywho tho............which would work better...........and aeroport.......slot port........or like a plain jane square box port?
Dan Tha Man
mustangfoo
Silver - Posts: 371
Posted: June 22, 2006 at 7:43 PM / IP Logged
I used PVC on my box as my ports, hits nice with em too for about $6 you can't go wrong.
aznboi3644
Gold - Posts: 2,600
Posted: June 23, 2006 at 1:57 AM / IP Logged
Either will work fine...Just make sure the ports aren't too small. For 15's...What do you guys think? Minimum of like a 5-6 inch round port?
arkansasboy
Member - Posts: 35
Posted: June 23, 2006 at 6:38 PM / IP Logged
yeah, probably like a 4 inch diameter hole......and have it like 10 inches long?.........but I should just have one right?
Dan Tha Man
dwarren
Posted: June 23, 2006 at 7:01 PM / IP Logged
There is a specific port diameter and length ratio that is porportional to the box size for a specific tuning frequency. A guess is not going to cut it.
aznboi3644
Gold - Posts: 2,600
Posted: June 24, 2006 at 1:31 AM / IP Logged
Lol I was just saying for the DIAMETER. Theres a port calculator on this website off to the left. Just mess around with those numbers until you get what your looking for.
Port diameter does go with box size i guess...Just don't put a 2 inch port in there. lol
arkansasboy
Member - Posts: 35
Posted: June 24, 2006 at 2:09 AM / IP Logged
Ooooo I see what your saying now..........so say if I cut my port exactly to that calculator what hertz would I want? probably 25-35 range? I'm hoping to enter my system into a few local comps......right now i'm hitting in the 145-150 dB range
Dan Tha Man
Thursday, February 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
