electrical system upgrade
samtucan11
Member - Posts: 17
Posted: June 26, 2006 at 9:04 PM / IP Logged
I am tryin to figure out how to determine what alternator, as well as how many batteries i will need to run my system. Is there any guidelines to determine these values. For example lets say i have a 5000 watt system, can i plug that into an equation, or some sort of outline to determine what size alternator i need, and how many batteries, or if i wanted an 8000watt system, same thing.... electrical system upgrade -- posted image.
stevdart
Platinum - Posts: 5,816
Posted: June 26, 2006 at 9:53 PM / IP Logged
The equation is good ol' Ohms Law.  Power is the result of voltage X amperage.  Voltage is the car system, and you can figure 12 volts for that.  If you were in with some competitors who beef up voltage to a higher number for comps, you would already have an inside track to what size alternator you'd need to get.  Batteries parallel-linked together still provide the same voltage, so there's no need to consider them in what you would need in an alternator.  You also have to consider what the car needs in power and then provide above and beyond for the sound system.
Amplifiers waste some of the power they receive, to boot.  Figure at least 30 to 40% waste in heat...so if you want 5000 watts of power you need to be able to feed the system enough current to equal about 7000 watts when multiplied times voltage.  7000 / 12 volts = 583 amps.
Realistically, what is it that you want to achieve?  Or is your question rhetorical only?
aznboi3644
Gold - Posts: 2,600
Posted: June 27, 2006 at 1:39 AM / IP Logged
5000 or 8000 watt system...Just go ahead and put dual HO alt's if you are thinking about that.
samtucan11
Member - Posts: 17
Posted: June 27, 2006 at 7:21 AM / IP Logged
i am asking, because i would like to end up with a system total of about 4k watts. When you talk about waste in heat, is that related to the amplifier efficeny at all? my amps would be RF 2000BD which should have an efficency of about 80% how would i figure it out then????
4000/.80 = 5000watts. then 5000/12 = 416 amps, would that be correct at all?????electrical system upgrade -- posted image.
aznboi3644
Gold - Posts: 2,600
Posted: June 27, 2006 at 4:10 PM / IP Logged
What are you goin to be running with that many watts?
samtucan11
Member - Posts: 17
Posted: June 27, 2006 at 4:41 PM / IP Logged
I wanna run (4) 15" L7's with (2) RF 2001BD's
stevdart
Posted: June 27, 2006 at 6:51 PM / IP Logged
You did the math right.  It won't turn out to be so cut-and-dried, but at least you know you're in the ballpark of what you need to do.  And yes, amplifier efficiency is the waste I was talking about.
samtucan11
Member - Posts: 17
Posted: June 28, 2006 at 8:37 AM / IP Logged
awsome, thanks alot!electrical system upgrade -- posted image.
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
