2/8 ohm speakers
cavyinthegarage
Copper - Posts: 52
Posted: January 11, 2003 at 10:58 AM / IP Logged
hello there,
after searching and reading alot of information,  I feel even more confused then when I started..  I need to know if you can make a pair of dual voice coil 2/8 ohm speakers to both be 4ohm.. I am trying to bridge an orion xtr175 at 4 ohms..
I went to fosgate website and the only way the chart said I could do this is from 4 dvc speakers... so I was just wondering instead of having to buy 2 more speakers or another amp... thanks for any input...
the12volt
Administrator - Posts: 3,957
Posted: January 11, 2003 at 11:26 AM / IP Logged
No, you can not wire two DVC woofers @ 8 ohms per voice coil in a 4 ohm load. You can wire them in 2, 8, or 32 ohms.
cavyinthegarage
Copper - Posts: 52
Posted: January 11, 2003 at 11:33 AM / IP Logged
ok thanks a million..
the12volt
Posted: January 11, 2003 at 11:37 AM / IP Logged
You're welcome, glad I could help.
If you ever need to determine resistance values of multiple speakers, you can always use these calculators: https://www.the12volt.com/caraudio/boxcalcs.asp#par
cavyinthegarage
Copper - Posts: 52
Posted: January 12, 2003 at 7:06 AM / IP Logged
I tried the calculators but I didnt understand how to make it work, thats when I went to the fosgate website like someone mentioned when I did a search...
but I understand it now I think 2/8 ohm speakers -- posted image.
thanks again tho for the help.. Im just going to get 2 more 10's
Sunday, December 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
