1997 astro van cd error
sledhead650
Posted: January 12, 2003 at 11:59 PM / IP Logged
my van has the theft-loc delco radio with built in cassette player and seperate cd player.they both stopped working on the same day,if you inserta cd or tape they stay in for about 7 seconds than the radio reads error and pops them back out..all the lights work ,everything seems to work on the radio except its not reading cd ortape,the battery was not disconnectedand no work done on the van..if anyone can help....please reply thx.
Chris Luongo
Platinum - Posts: 3,746
Posted: January 13, 2003 at 5:23 PM / IP Logged
If you have the theft code on hand, try unplugging the units (or disconnecting the battery) for a few minutes, then hook it back up again, and see if this makes any improvement.
Also, do some "delco" and "delco cd" searches on eBay; a used replacement may be cheaper than getting yours repaired.
sledhead650
Posted: January 13, 2003 at 7:29 PM / IP Logged
thx for reply,,disconnected the battery ands radio did not lock,,so it must have been disabled,,,in will try some other things ,,checking wires and get back to you ,,,thx again.
sledhead650
Posted: January 15, 2003 at 6:29 PM / IP Logged
i got that cd player figuired out,,the problem is the disc is turning really slow and then stops completely and then turns slow again,,too slow for the lazer to pick up on it.....i don't know if there is an adjustment on delco cd players to fix this problem,,or is it time to take it in the shop or buy a new one..???
pervitizm
Copper - Posts: 125
Posted: January 15, 2003 at 11:52 PM / IP Logged
If I were you, I would ditch the factory HU and go for a nicer and better sounding aftermarket HU. Your gonna spend way more trying to get that HU from delco fixed
live & die 4 tha luv of BASS!!!!
Chris Luongo
Posted: January 17, 2003 at 9:46 AM / IP Logged
I'd never downgrade to an aftermarket radio unless I had to.......plus, there's no direct-fit way to get CD and cassette in an Astro except for the Jensen unit.
If you're sure it's just the remote CD player, pick one up on eBay; they go for around a hundred bucks usually.
Carsound1
Member - Posts: 24
Posted: January 17, 2003 at 9:11 PM / IP Logged
Pioneer and JVC both makes double din units for GM vehicles with the cd/tape combo
i know cause the guy i work with has one in his Astro Van
just take a look in the Pioneer and JVC catalogs
pervitizm
Copper - Posts: 125
Posted: January 17, 2003 at 11:17 PM / IP Logged
I don't see how going with an aftermarket HU is a downgrade? After all aftermarket HU are not only superior in sound quality, but they allow for easy system upgrades, like external amplifiers and not having to worry about security codes from OEM stereos. Just my two cents
