radio, 95 ford explorer
aerials
Member - Posts: 6
Posted: July 23, 2006 at 6:37 PM / IP Logged
ok read the forums didnt ever see a actual answer.. heres the jist of it. i have a ford explorer and ford winstar.. bought a radio "after market" and had it installed in the winstar, well now my wife wants it in the explorer after i paid a arm and right leg and kidney to get this installed in the windstar.. now i bought the wiring kit, hooked it up, nothing i get power and so forth but no sound.. i tried to direct wire it tried every combination with the thing.. still no sound no static nothing, i used a wire tester to find the +'s and -'s for each wire, got that done so tried again... no sound so somewhere im doing something wrong, or this had a pre installed amp "if it does could that be the prob," and if so can i just bypass that?? ANY help would be great im going nutts here and she driving me insane wanting this hooked up.. I have installed 100's of radios before and Never had this issue
josh1979
Silver - Posts: 320
Posted: July 23, 2006 at 7:59 PM / IP Logged
ther is a good chance that you exp has a foctory amp. what year do you have?
bring back the rotary phone so i dont have to press 1 to proceed in english
KarTuneMan
Platinum - Posts: 7,056
Posted: July 23, 2006 at 8:05 PM / IP Logged
josh1979
Silver - Posts: 320
Posted: July 23, 2006 at 10:22 PM / IP Logged
KarTuneMan wrote:
Like the topic says...it's a 95 And it MIGHT have an amp.
sorry i missed that 95 part
aerials
Member - Posts: 6
Posted: July 24, 2006 at 2:59 AM / IP Logged
if its in the Kick panel on the passanger side and Blue then yes i do... i read about the amps here and checked it's a small one if it is...  totaly re-wired the front doors today, would rather just go back and use the wiring kit if possible.. the manufacture date on the explorer is 3/95 if that matters
But back to the amp.. is that a amp and can that be used? or should i just bypass it?
aerials
Member - Posts: 6
Posted: July 24, 2006 at 3:01 AM / IP Logged
https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1995-96&make=Ford&model=Explorer&ID=17798&type=Stereo
Ok ill try these monday its 4 AM here and ive had it lol thanx
aerials
Member - Posts: 6
Posted: July 24, 2006 at 3:05 AM / IP Logged
one more thing.. on the speaker side wiring harness there is a big black wire along with the 8 colored speaker wires whats that for if anything.. and to hook this radio up should i hook that amp remote to the radio as well?
aerials
Member - Posts: 6
Posted: July 27, 2006 at 2:56 PM / IP Logged
the wireing chart worked!!! Woot.. thank you soo much
