loud popping noise at turn on
lish
Posted: July 31, 2006 at 4:34 PM / IP Logged
i just replaced the factory head unit in my 2004 f-150 with a pioneer deh-p880prs.  the rest of the system is still the stock ford audiophile system which includes a small subwoofer with amplifier under the rear seat.
when i turn the system on i get a lound pop...  i think it's coming from the factory sub when the amplifier is triggered to turn on.  after the system is on it sounds good and i don't get any popping when switching from one source to another.
thanks for your help.
djfearny2
Silver - Posts: 810
Posted: July 31, 2006 at 6:54 PM / IP Logged
get your self a dei turn amp turn on device. what will happen is this.
you wire it in line with the remote turn on lead of blue wire from pioneer unit. which means you disconnect the blue wire and wire this dei amp turn on betweent he radio and the factory amp turn on wire.,
it is a dei remote power adapter by dei available at www.selectproducts.com under the directed electronics section
Jon
Installer/Help Technician
---coral springs florida---
Hornshockey
Silver - Posts: 520
Posted: July 31, 2006 at 11:25 PM / IP Logged
a cheaper option to try would be placing a 1.5k ohm resistor inline on the amp turn on wire from your head unit.  This should fix your problem.
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
Wednesday, March 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
