Wiring layout 95 Mercury Villager
myself2
Posted: August 21, 2006 at 11:56 AM / IP Logged
Hello to all. My dilema is that I have a radio that I have to install into a 95 Mercury Villager which has a factory amp. I got the wire harness that goes along with it but noticed that only the power,ground,illumination connection can be used due to the fact of the factory amp. I was wondering if anyone could assist me in installing this from the radio plug output to the amp. Or should I just bypass the amp and run wires to the back where the outputs go to the speakers?   Any info would be greatly appreciated.
geepherder
Platinum - Posts: 3,668
Posted: August 21, 2006 at 9:04 PM / IP Logged
It sounds like you got this harness: http://www.scosche.com/scosche_caraudio.aspx?ItemID=FD02B&CategoryID=78
Take it back and get this one: http://www.scosche.com/scosche_caraudio.aspx?ItemID=FDK4B&CategoryID=78
It should be a straight forward install after that.  Be sure to connect the factory amp turn on lead (maybe blue or blue/white).
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
