Subwoofers Popping
banginloud
Member - Posts: 18
Posted: August 27, 2006 at 9:49 PM / IP Logged
My subs seem to pop extremely loud when I first turn my vehicle on in the mornings.Just curious as to what could be causing this and if it is damaging my subs?
aznboi3644
Gold - Posts: 2,600
Posted: August 27, 2006 at 11:12 PM / IP Logged
Ground problem...or crappy amp...could be something else
Steven Kephart
Platinum - Posts: 1,737
Platinum spaceThis member has been recognized as an authority in Mobile Audio and Video. Click here for more info.spaceThis member consistently provides reliable informationspace
Posted: August 28, 2006 at 3:35 AM / IP Logged
Most amplifiers employ a delay turn on circuit to prevent that from happening.  It sounds like your amplifier doesn't employ such a device.  It shouldn't cause any damage unless there is a large mis-match of amplifier power to mechanical power handling of the speakers.
banginloud
Member - Posts: 18
Posted: August 28, 2006 at 11:01 AM / IP Logged
I suppose I may check the ground first.As far as the amp it is far from crappy,its an old school Kenwood Kac-1023.I just couldn't imagine an amp of this caliber not having a delay turn on circuit.Maybe it doesnt though who knows.
killer sonata
Silver - Posts: 718
Posted: August 28, 2006 at 1:05 PM / IP Logged
you keep it poppin? you show, show stoppin? check all your grounds with a DMM
Steven Kephart
Posted: August 28, 2006 at 2:43 PM / IP Logged
It's not a question of quality.  It just depends on whether the company decided to include that circuit.  A/D/S/ amplifiers didn't employ one of those circuits IIRC and they are very highly reguarded.
zerepdivad
Silver - Posts: 605
Posted: August 28, 2006 at 2:59 PM / IP Logged
I had this same problem with my setup. But what was weird is that when i changed out my headunit the popping magically disappeared. everything else remained the same.
geepherder
Platinum - Posts: 3,668
Posted: August 28, 2006 at 8:56 PM / IP Logged
David,
that's probably because you're gains weren't set properly, and the new headunit had a lower voltage output, which better matched the amp.
