How does a factory Remote wire work
sub-zero
Posted: September 21, 2006 at 9:56 PM / IP Logged
i would like to know how an automobile remote turn on system work. I am curious because i want wire up my car stereo equipment in my room all in a nice box shelf. How do i make a remote turn on for the set up when it is not hooked up to a car. Thanks everyone.
auex
Platinum - Posts: 5,041
Posted: September 21, 2006 at 10:14 PM / IP Logged
All it does is supply +12V when the radio is turned on.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
sub-zero
Posted: September 22, 2006 at 7:57 PM / IP Logged
So can i just ignore the blue remote wire on the radio and supply 12 volts to the radio from a car battery, or should i hook up the blue remote wire from the radio to the amps while plug in to the battery.
auex
Posted: September 22, 2006 at 8:36 PM / IP Logged
Well, if you are just hooking up the radio then you want to power the yellow(constant) and the red(acc) wire and then ground the black(ground) wire. If you are using an amp then you need to worry about the blue wire otherwise leave it unhooked.
sub-zero
Posted: October 02, 2006 at 6:36 PM / IP Logged
I would like to connect both my amps and sub woofer all together with the radio.
soultinter
Copper - Posts: 170
Posted: October 03, 2006 at 3:57 PM / IP Logged
you should buy a good size inverter (ac to dc) to power your radio and amp(s).
