Installing amp for subs but amp doesn't turn on
syomau
Posted: January 20, 2003 at 7:41 PM / IP Logged
I am in the process of installing a jensen 500watt amp for two 10" subs. I have already dragged and hooked up all of the wires needed. I checked the voltage being put out by the power wire and its 12v. The remote is hooked up to my pioneer 6400 deck to the antenna cable. The amp just will not turn on, I'm  lost on what to do.
Derrik
Member - Posts: 46
Posted: January 20, 2003 at 8:15 PM / IP Logged
hmm...good ground (paint free)??? fuse on amp??? remote line got voltage as well????
wvsquirrel
Gold - Posts: 1,237
Posted: January 20, 2003 at 11:04 PM / IP Logged
Try turning on just the radio.  Some HU's only supply juice to the power antenna wire when the radio (not CD or tape player) is on.  If this is the case, you'll need to rig the remote to something else.  Cigarette lighter works, but you have to install a toggle/rocker switch to manually turn the amp on and off
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
syomau
Posted: January 21, 2003 at 2:56 PM / IP Logged
Good ground, using the one honda has, tried radio on as well as cd player. The remote had something like 4 volts goin through
syomau
Posted: January 21, 2003 at 4:54 PM / IP Logged
the fuse is also fine
ViperATC5
Copper - Posts: 202
Posted: January 21, 2003 at 5:00 PM / IP Logged
remote wire needs 12 volts to power up your amp - try connecting your remote turn on lead to your switched ignition wire
syomau
Posted: January 21, 2003 at 8:48 PM / IP Logged
Thanks, hope thats the problem ,can u give me a site with diagrams or instructions to do that for a 2000 accord
Sound Pressure
Silver - Posts: 711
Posted: January 23, 2003 at 12:25 AM / IP Logged
Here you go syomau,
https://www.the12volt.com/installbay/detail.asp?info=alarm&year=2000&make=Honda&model=Accord&ID=17963&type=Stereo
Sound Pressure
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
