i have a problem with blowing amps.
chris305
Member - Posts: 40
Posted: January 13, 2007 at 10:54 AM / IP Logged
is it true that if your voltage drops to low for to long will it blow your amp? cause i have 8 12in kicker cvx dual 4ohms. with two power acoustik 4200rms at 1ohm. with 2 yellow tops in the back and one red top for the front. and a 300amp alternator. and this is the second amp i have blown. i do play it on idle sometimes and the amp blows in a day. now when i do play it my voltage goes to 11. something and stays around 12.something while im playing it on idle. do i not have enough batteries or what's? need help to figure out why i keep blowing amps
DYohn
Moderator - Posts: 10,741
Posted: January 13, 2007 at 11:16 AM / IP Logged
11-12 volts is not likely to lead to blown amps (although they are Power Acoustik so who knows?)  More likely is you are overloading them.  They may be stable at 1-ohm, meaning they do not go into protection, but this does not mean they are actually designed to sustain a 1-ohm load for very long, especially not at high volume levels.  I suspect you are simply pushing low-end amps too hard and they are burning up.
chris305
Member - Posts: 40
Posted: January 13, 2007 at 1:07 PM / IP Logged
what you mean low end amps to hard and are burning up?  what is in the amp is buring?
DYohn
Posted: January 13, 2007 at 1:22 PM / IP Logged
If my guess is correct you are most likely burning up an output transistor or two.  Pushing them too hard + low build quality = they get too hot and fail.
chris305
Member - Posts: 40
Posted: January 13, 2007 at 1:51 PM / IP Logged
oh ok so how to you provent that? and is it fixitble?. also what the amp does is that when i turn off the car the light of the amp stays on too. and even if i take out the remote wire. only way to shut off the amp is taking the power wire out. why does it do that
aznboi3644
Gold - Posts: 2,600
Posted: January 13, 2007 at 2:05 PM / IP Logged
you can prevent that buy wiring the amps at 2 ohms...if you can.
He means even though the Power Acoustik amp says it is stable at 1 ohm the amp MOST lIKELY will not live for long being pushed at that load...because of crappy quality prolly
Also how are your gains set???
jeffchilcott
Platinum - Posts: 2,483
Posted: January 13, 2007 at 2:34 PM / IP Logged
The way I look at it you have $1200-$1600 in woofers, $500-$600 in batteries, a good $400 in your alt
but only a $200 amp?     whats wrong with this picture?
You have woofers that will handle up to 6000 Watts RMS
Why dont you look into something higher quality that would match the rest of the good equipment you already have
Look into a pair of kicker KX2500.1   They will produce real power not just boasted numbers and are very reliable
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
oxygen65
Silver - Posts: 252
Posted: January 13, 2007 at 4:01 PM / IP Logged
what about a earthquake phd5000, i kno it says that it is 2 ohm stable but i called earthquake and they said that it is 1 ohm stable as long as you dont run it under 12 volts.  so does that mean that i can run it at 1 ohm all day and run it pretty hard? or is it gonna blow like the power acoustiks amp?
jeffchilcott
Posted: January 13, 2007 at 4:53 PM / IP Logged
i would say if it dosent say it in the factory specs I would be a little leary.   If you can get a email from earthquake saying they will repair it if it blows up, then I would go for it
2007 World Record
godblessdremil
Silver - Posts: 273
Posted: January 13, 2007 at 5:38 PM / IP Logged
You spent the money for the system. If you really want to go cheap get an alphasonik amp, they got a long warranty and i put them through a alot of doodie even outlasted a JL amp. And they are 1 ohm stable. Stop thinking cheap on the amps you invest so much in the other stuff and you bitch out on this one thing.
Friday, December 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
