bazooka rsa150 2hc amplifier
samuelsteven
Copper - Posts: 123
Posted: February 12, 2007 at 1:29 AM / IP Logged
I just picked up a Bazooka RSA150 2HC amplifier. It says its 1 ohm stable, but does anyone know the actual wattage? Will it push out more power at 1 or 2 ohms? Im trying to puch 2 memphis M1 15"s. There dual 4 ohms.
outtaluck72
Copper - Posts: 155
Posted: February 12, 2007 at 12:31 PM / IP Logged
I've got 2 running at 2 ohms mono running 4 Bazooka RX-T2 subs and doing fine, but I feel they are not putting the power out like they should.  Bazooka says 1000 watts at 1 ohm I believe, but that would be at best. at 2 ohms the amps get hot so 1 ohm would really get them hot.
aznboi3644
Gold - Posts: 2,600
Posted: February 12, 2007 at 4:23 PM / IP Logged
You can bridge it at 4 ohms and get 250 watts per sub if the amp puts out rated power.
Or wire em 2 ohm stereo...either way same output.
That amp cannot handle a 1 ohm MONO load
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
