cleanest way to get signal from oem radio
Raymond4646
Copper - Posts: 121
Posted: March 20, 2007 at 10:08 PM / IP Logged
Car is an 03 Eclipse GTS with Infinity 7 channel system.  Are line output converters still used on speaker leads?  Anything from Pie or Pac worth looking into?  Thanks
loosingmymind
Copper - Posts: 103
Posted: March 22, 2007 at 10:45 PM / IP Logged
Try the PAC SNI-35 because you can adjust it. Or the Periphreal piece.
They should work,
David
David Fancher
USACi World Finals 2006
4th Place SQ PRO 601+
Raymond4646
Copper - Posts: 121
Posted: March 22, 2007 at 11:27 PM / IP Logged
Dave, I wasn't sure if these style hi/low converters were the way to go now a days.  Its been about 9 years since I've really been into the game.  Never in any comps. like you though ... Congrats to your 4th place victory.  And thanks for you help!!!
loosingmymind
Copper - Posts: 103
Posted: March 22, 2007 at 11:43 PM / IP Logged
Thanks bro. Hope it works out for ya.
Dave
David Fancher
dwarren
Posted: March 23, 2007 at 1:17 AM / IP Logged
There are higher end pieces like the JL clean sweep or fosgate 3sixty. These are ideal for retaining stock h/u's and adding amps.
But there isn't any thing wrong a Sven 4 from peripheral either.
pldtj
Member - Posts: 16
Posted: March 23, 2007 at 1:24 AM / IP Logged
I have the Sven 4 on my system,works great alot of adjustability I paid nearly $50 for it at Fry's electronics
Raymond4646
Copper - Posts: 121
Posted: March 24, 2007 at 11:50 PM / IP Logged
dwarren and pldtj thanks for the choices!!  I ended up picking up a PAC unit the other day.  I didn't feel the dei hi/low converter was worth. lol
loosingmymind
Copper - Posts: 103
Posted: March 25, 2007 at 2:55 PM / IP Logged
Set it up right and it should do fine.
David Fancher
Raymond4646
Copper - Posts: 121
Posted: March 25, 2007 at 3:11 PM / IP Logged
Hey Dave,
As as setting it up right are you referring to adjusting the output on the PAC unit correctly? Thanks
loosingmymind
Copper - Posts: 103
Posted: March 25, 2007 at 3:44 PM / IP Logged
Yesir..
David Fancher
