dvc
tagminion
Posted: May 13, 2007 at 7:52 PM / IP Logged
ok i got 2 Dvc 4 ohms xtants and when i wire them for a 4 ohm app they work fine but when i try wiring them for a one ohm load only one of the subs works and the other one keeps tripping the amp....i tried it by itself and it still didnt work...why would it work being set up for 4 ohms but not 1? the other one works fine im so lost if someone could help me out thanks
aznboi3644
Gold - Posts: 2,600
Posted: May 13, 2007 at 9:41 PM / IP Logged
What amp do you have???
meter the coils and check if they are anywhere near 4 ohms
stevdart
Platinum - Posts: 5,816
Posted: May 13, 2007 at 11:21 PM / IP Logged
Check to see if you have:
1.  Exact same signal input to both subs.
2.  Exact same resistance measurement across terminals of both subs.
I suspect you will find a lower resistance on that troublesome sub than the other one.
DYohn
Platinum - Posts: 10,741
Posted: May 13, 2007 at 11:38 PM / IP Logged
Probably because your amp cannot handle a one-ohm load.  What amp?
tagminion
Posted: May 13, 2007 at 11:39 PM / IP Logged
im running a kicker zr240 i think thats what it is....says stable down to one ohm...it works fine for one of the subs but not the other like if i wire it by itself for 2 ohms it still wont work it only works at 4 ohms
jeffchilcott
Platinum - Posts: 2,483
Posted: May 14, 2007 at 6:23 AM / IP Logged
That amp is only stable to one ohm stereo.   not bridged.   If you are attempting to run the 2 subs bridged it will cause serious damage to this amp
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
jmelton86
Gold - Posts: 1,228
Posted: May 14, 2007 at 8:50 AM / IP Logged
Yep. You can't get full power from that amp with those subs. If you had 2 2ohm dvc subs you could (1ohm each channel). Your only option, for most power output, is to run it 2ohm stereo.
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
