2006 altima, unit plays w/o ground lead
14.4eddy
Posted: May 30, 2007 at 1:04 PM / IP Logged
While trouble shooting a problem with a deck I just installed in a 2006 altima I noticed that the decks ground wire had come undone but the deck was still working how is this possible
the12volt
Administrator - Posts: 3,957
Posted: May 30, 2007 at 1:10 PM / IP Logged
The head unit is still grounded through its chassis and/or antenna.
2006 altima, unit plays w/o ground lead -- posted image. the12volt • Support the12volt.com
sqsq
Copper - Posts: 51
Posted: May 30, 2007 at 10:44 PM / IP Logged
Its grounding through the antenna but you still want to hook up an actual chassis ground.  The antenna ground isn't sufficient to fully power an aftermarket deck--so if you turn up the volume really loud (while using only the antenna as a ground) you will often times find that bad things happen such as the deck turning off, cutting out, dimming etc.
Friday, December 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
