Factory Amp Location, 1997 Lexus ES300
dwarren
Posted: August 11, 2007 at 3:44 PM / IP Logged
May need to do an amp bypass, so I need to know where it is. 1997 Lexus ES 300.
Thanks.
Bnluis
Silver - Posts: 578
Posted: August 11, 2007 at 3:53 PM / IP Logged
Its behind the glove box right side of dash. You couls also use a metra wire harness and leave the factory amp in there. I think the part number is 70-8112 or 70-8113
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
dwarren
Posted: August 11, 2007 at 4:02 PM / IP Logged
I am using the 8112, but like all the lexus's I've done in the past, it has engine noise.
Thank you for the info.
mando2155
Copper - Posts: 74
Posted: August 12, 2007 at 3:48 AM / IP Logged
if its a nakamichi system its behind the glove box  above the kick panel.(pain in the butt.)   If its the pioneer system its under the pass seat.  eaither way its a normal toyota harness at the amp.  Ive always had the 8112 work well when i use it,  what head unit are u using?
Bnluis
Silver - Posts: 578
Posted: August 13, 2007 at 8:15 PM / IP Logged
try using 2 ground loop noise filters in vetween see if it solves the engine noise. It has work for me in certain cars,
http://akamaipix.crutchfield.com/products/2004/127/h127SNi1-f_dg.jpeg
Luis
Sound Waves
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
